Acrobat Pro 10 with Catalina
Is it possible to run Acrobat Pro 10 on Catalina? I haven't upgraded because I use this software often.
Adobe Acrobat X will not work in Catalina due it not being a full 64-bit application. The system requirements for it are as follows:
Mac OS
  • Intel processor
  • Mac OS X v10.5.8 or Mac OS X v10.6.4
  • 512 MB of RAM (1 GB recommended)
  • 1.2 GB of available hard-disk space
  • 1024x768 screen resolution
  • DVD-ROM drive
  • Safari 4 for Mac OS X v10.5.8; Safari 4 or 5.0.x for Mac OS X v10.6.4
You would need to upgrade to the current version.
